Tein SS Coilover setup
hi everyone,
i just got my tein SS coilover yesterday
and i need help with the lowering
i am plannin to drop at around 2"
but i heard that the front and rear is not even with the gap
so how much should i drop the front and the rear to make it the same??
Photography Nerd
Just use a good guess when you're installing your suspension, then after the car is on the ground, measure the gaps and see how much you need to adjust it. Then jack the car up and adjust the spring perches accordingly.
Photography Nerd
You'll be able to get close during the install but it won't be 100% perfect until you can adjust it on the ground. Adjusting it once you get it on the ground is part of the installation.
Rep'n Taxbrain.com
Originally Posted by 21Tsx
but im hoping to get it right on the first try cuz im tellin others to do it for me
Either way, make sure you understand how to adjust the suspension before you leave the shop. It's not too hard.
2004 NBP/ebony AT
good choice man, i am still waitin on mine to get in, but tell them to make an easy way for u to get to ur rears so u can change the dampening, im gonna go with a one finger or less i think.
Originally Posted by kaliraver69
What is the highest and lowest settings for the Tein SS as far as inches go?
The rear is down 15mm to 61mm, or .6" to 2.4".
The Basic uses the same springs and strut, and the drop is the same. Just no damper adjustability.
so the basics you only adjust them once you put them basically? and the other ones you can adjust them whenever you want?
You can adjust height to your heart's content though.
2004 NBP/ebony AT
Former Sponsor
so does anyone know how much to drop the front and rear, to leave a one finger gap???
im plannin to do 2.1 front and 1.8 rear
is that good???
is that good???
Hey, check out Tein's specs...
http://www.tein.com/acura.html
If you follow the installation instructions to the tee......the SS will drop the car 2.0 in the front and 1.6 in the back.
I would tell them to follow the instructions exactly, and them move the collars down about 1/8" if you want it lower.....
The factory settings put the car at a really nice level....
Marcus
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
