Stock Suspension, Negative Chambers
I have a 2005 TSX with a stock suspension, but the back tires have reasonably noticeable negative chambers. How does this happen? How do I fix it? I brought the car to a place and they said the only way to fix it is by getting adjustable chambers. But I've read in some places that you could just fix it by getting an alignment. PLEASE HELP!
have an 05 myself... negative camber is not necessarily bad as long as it's within factory spec no more than -1.5 & anything beyond that will require a camber kit. if you have noticable inner tire wear this is likely the problem. you will need to buy a kit before an alignment. other issues contributing could be worn suspension components like your shocks. a reputable shop should be able to help determine the problem. hope this is helpful...
have an 05 myself... negative camber is not necessarily bad as long as it's within factory spec no more than -1.5 & anything beyond that will require a camber kit. if you have noticeable inner tire wear this is likely the problem. you will need to buy a kit before an alignment. other issues contributing could be worn suspension components like your shocks. a reputable shop should be able to help determine the problem. hope this is helpful...
To the OP, if your suspension is stock and you really do have camber issues, then perhaps there's something else going on. But even if it's a little excessive, it's not a problem unless it's how the rear wheels look that's really bugging you. You'll get all kinds of suggestions on where to go for an alignment, but since it seems that this the first time (for you) I'd take it to a Honda or Acura dealer and let them look at it.
Former Sponsor
The INGALLS rear camber/toe kit will solve your issue. Qty of 2 required:
http://store.excelerateperformance.c...5/i-60220.aspx
1fatcrxnem1
22
06-01-2018 01:23 AM
mrkingstonvi
02-22-2016 01:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
