stock OEM bushings work with Progress rear sway?
I spend 2 much time here
My bushings are gone on my progress rear sway, what are my replacement options?
can i go with stock OEM acura ones?
Let me help you!
I'm not sure about Progress (I have a comptech sway bar), but these are probably your options:
1. replace them with ES polyurethane bushings...you can order them at summitracing (http://store.summitracing.com/egnsea...4294869136+115)
2. There's a different part # for ES poly bushings that are greaseable....that requires modification (i didn't jot down that part number)
I'm not sure, but I don't know if the OEM rubber bushings will fit (I'm having a brain fart and can't remember how thick the diameter is for the OEM sway bar)
