Spring Confusion, Help ?
I recently purcahed a set of RS-R down springs for my TSX,
1.6 Front / 1.3 Back. My concern is the car is going to be to low to the ground.
A friend is selling a set of four (4) Eibach Pro-Kit Springs
Part number 4045.140
Lowers front by 1.4" and rear by 1.2"
Do you guys think its worth buying the Eibach set? is it worth spending the extra money?
i would go for the eibach if it doesn't cost that much. If you were planning to use the OEM shocks, they would probably die out sooner if you had a lower drop. I have the Eibach springs and I dont' think I would want to go any lower. i never posted a picture before of my car, but I'll see what I can post in the coming days. FYI my car is always dirty and has some scratches on the front bumper I'm not so happy about.
You probably get that much of a difference when you sit in the car, or fill the tank.
But, I'd go with the Eibach's between these two, and get yourself some Koni's or Tokico's.
Originally Posted by CGTSX07
agreed..it is better to swap the shocks and springs at the same time bc your stock shocks won't last long at all
do you know this for a fact or are you just saying this.. i had after market springs on my civic with stock shocks and they lasted 80k+ miles on that set up.
Thanks for the input guys, I read about the premature shock wear, and decided to pick up a set of Tockio HP Blue’s shocks, I am still however undecided. I picked up the RS-R springs from an online vendor, the main reason I am concerned is about the quality of the springs? Or the spring rates. However I believe the Eibach is a reputable brand?
Anyway if this makes a difference I am getting the Eibach set for $110 CDN.
Is waiting in
RS*R makes some nice products, I wonder if they plan on making an exhaust for our car. You should be fine with those springs and Tokico struts. I also think you would be the first with that suspension combo, so why not be a pioneer?
TF500
I've got the Eibach springs with Bilstein shocks.Drop is just right.This setup transformed my car,firm but progressive,so yeah change the shocks while you're doing the springs.BTW don't forget the rear camber kit.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
