Running 255/35/18 tires with no drop = 4x4?
Hey everyone,
I was wondering if i ran 255/35/18 tires on 18x8 wheels, and I have no drop (06 AT), will it look very 4x4ish or rub? I ran the tire calculator and the difference was in the sidewall (stock being 4in and this being 3.5).
If anyone can provide any further insight, that would be great.
Thanks.
Thanks.
255 is way to wide for the little TSX. The widest you would be able to go is about 235. If you don't lower it might not rub but if you do to get rid of the 4x4 look it will definitely rub.
Originally Posted by Patel404
I just put 245/40/18 on my 06 with no drop and it doesn't rub at all.
Why are you guys running such wide tires on an 8" wheel? You do know that rubbing should be less of a concern when compared to sidewall flex. At those widths, I wouldn't be surprised if your tire rolled over on a hard corner.
My
My
My![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
My
OE 17x7 wheels seem popular) but performance suffers.
boost owns
My
Originally Posted by Audioserf
Agreeing with this. I just got my new 18x8 rims on today and I'm running 235/40/18 tires and it's absolutely perfect. I can't imagine needing any more width than that on an 8" wheel.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
235 is pretty much the optimal width for the 8" wheel width. You could go to a 245, but you want to make sure that the offset will keep the tire from extending beyond the fender line.
255 is just too wide unless you're running a 9" wheel and even then, only in the rear.
boost owns
Ah, I love the 04 TL A-Spec rims. So sexy. Nice, man. As for "4x4" I personally hate that analogy only because my roommate drives a Montero Sport, and I could fit my head between the top of his tire and the bottom of his fender, so it's a stupid exaggeration. But your car could do with at least a slight (A-Spec) drop (in my opinion).
The 245 tires look fine, though. No problem with those on an 8.5" wheel.
I would lower it but people have told me that it might rub if I lower it more than an inch. I have the extended warranty and I don't know if acura will warranty it if anything goes wrong unless I use a-spec, but I could be wrong. I heard that the a-spec kit lowers it more than an inch in the back so it would probably rub.
1fatcrxnem1
22
06-01-2018 01:23 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
nuldabz
09-03-2015 05:49 PM
