rotating directional tires
Old 07-31-2006 | 02:04 PM
formerRSX-S's Avatar
How often should tire rotations be done for directional tires? Thanks.
Old 07-31-2006 | 02:07 PM
jerzpwr's Avatar
20,000 - 25,000 ?
Old 07-31-2006 | 02:21 PM
xizor's Avatar
Bye TSX, hello domestic?
Originally Posted by jerzpwr
20,000 - 25,000 ?
i'd say lower since they're directional and likely summer tires, a set of ES100's wouldn't even last 20k miles total. i'd do 5k miles if you're handy
Old 07-31-2006 | 03:19 PM
Savio's Avatar
TSX
every oil change
Old 07-31-2006 | 03:35 PM
jlukja's Avatar
So, do you rotate them front-to-back only or do you take em' off the rims, cross rotate, and remount/balance etc. ?
Old 07-31-2006 | 04:01 PM
Kighter's Avatar
If you're properly aligned and balanced - front to back should be all you need.
If your camber is off - either accidentally or by choice - or you have some other alignment issue remounting on the other side of the car might buy you a little more mileage on the tire once you fix the problem. But that's a costly way of rotating.
Old 07-31-2006 | 04:13 PM
hawaiiantsx's Avatar
if you have directional tires, you can cross rotate the tires....it would only have to be front to back
Old 07-31-2006 | 05:42 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ I think you met to say "cannot cross rotate", but yeah.
Old 07-31-2006 | 06:09 PM
ILoveMyHonda's Avatar
17781708
you CAN technically cross rotate directional tires.......the directional part is mostly for water evacuation......so if u know for sure u will NEVER encounter standing water or rainy conditions.....it can be done.
Old 07-31-2006 | 06:52 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
I rotate my Yokohama ES100's every oil change/every 5,000 Miles and have over 40,000 Miles on them with one track day under it's belt.
I also have my tire pressures set at 34F/32R.
Old 07-31-2006 | 08:22 PM
mg7726's Avatar
She said: it's GINORMOUS!
i don't cross rotate my directionals. and i've gotten 26k miles out of my potenza re050s.
Old 07-31-2006 | 08:57 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Dang 40K, that's really good man
Old 07-31-2006 | 09:08 PM
joerockt's Avatar
Just dial 1911
I get mine done for free every 3K at americas tire.
And if you have Ultra Summers, your not going to want to wait much longer then that.
Old 08-01-2006 | 11:46 PM
thanks for the feedback. I'll keep it close to the 5k mark.
Zonian22
11-14-2015 02:20 PM
real_mckoy
4G TL Problems & Fixes
09-25-2015 11:49 PM
GhostTL09
09-19-2015 02:57 PM
datadr
09-12-2015 10:12 PM
Zonian22
09-02-2015 09:19 AM
