question on ingalls
question on ingalls
hey whats up just had a question on ingalls camber kit for 05 tsx, i have tein ss coil overs lowered 2 inches im going to put the camber kit in soon and was just wondering if the toe kit had to go in to,is there away i can adjust to camber kit to specs or do i have to bring it some where thanks
The rear ingalls camber kit allows both camber and toe adjustment. With 2" of lowering, you will definitely need to adjust the camber. Doing this will throw off the toe. Once the camber is set, the toe can be adjusted w/ the stock cam adjuster or via adjustment of the ingalls arms.
I have the Ingall kit and as AlterZgo says, it adjusts toe. In addition to AlterZgo's comments, anytime you move camber on our 5 link system, it effects toe and although the TSX has some ability for toe adjust in the rear stock, the Ingall gives you as much as you need. My mechanic, who used to only use SPC, loved them.
I have an 05 TSX with Tein SS and Ingalls rear camber dropped 2". It does everything you need for the rear.
And yes! You should take it to someone for a professional allignment. Your tires will love you for it!
Even with major lowering in the front, the camber stays within factory specs. So no need to buy stuff for the front. The stock adjustments for toe will suffice.
Former Sponsor
Well, not really...
Lowering the car messes up the camber AND the toe. Adjusting the camber does not change the toe, nor vice versa.
However, the car does have adjustable toe from the factory, and the toe wears out tires very fast.
Many times I find a camber kit is not needed since camber does not wear tires very fast or aggressive like toe does.
That being said, teh ingalls does have more adjustment than spc.
Originally Posted by MrHeeltoe
Well, not really...
I have to disagree with your disagreement.......
To quote from the instructions:
And when I watched the tech to do the alignment, this was certainly the case on my TSX......
Former Sponsor
I think that might have more to do with the design of the Ingalls kit.....the toe adjustment is moved closer to the hub, and it is not a stritly lateral adjustment. For where you adjust the toe, I can see how it would affect camber. But with the standard adjustment method it is not an issue.
I just got my TEIN SS's, comptech RSB and ingalls Rear camber kit last week. After doing some research and searching the board, I'm curious if i should even install the rear camber kit. Should I leave it off and let a shop do it along with the alignment or should I put it on? Also, if I do put it on, how do you know what setting you're at?!?!
I use the bolts that come off the rear camber kit to get the close approximation to the stock lengths. Just make sure you twist the center bar of the kit so that you get equal lengths on both sides of the bars.
I always put the ends as far in as possible with the lock nuts on then put the bar on the ground and twist from the bar so each end equally pushes out.
You might want to put some anti-seize on the threads too as you put them together.
Note, 2 of the ends per kit have thicker bushings, so make sure you put those on the right bar. I believe the thicker inner bushings go on the camber bar and not the toe bar if my memory servers me correctly.
Thanks! Going to give it a shot on Saturday.
DerrickW
11-15-2015 05:52 PM
lanechanger
10-13-2015 10:56 AM
