psi?
The Power of a Grill
psi?
what would you recommend as ideal psi for my 04 6m tsx with the 05 TL wheels and tires (michelin)? same as tsx (30/32) or same as tl (35/37) or somewhere in-between?
i had it on 35 all around at first, got them balanced and they put it at 30/31 - they said that the tire psi should be matched to the car specs, not the tire specs. So anyway, the ride seemed a little rougher after the balance. so i bring it in after about 3k miles, ask for a balance and rotation and to be put at 35 psi. when i got the car back, they said 2 tires were off balance. anyway, car now runs smoother and a little firmer on the wheels now at 35. i may lower down to 32 all around just to see if it will be a little less stiff.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
