Progressive Rear Sway Bar Question
Hey guys, I just got the progressive rear sway bar, and it's an adjustable sway bar. Do you guys recommend using the softest setting or the tighter one?
For those who had tested the two settings, are there any major differences between them?
I have the Progress bar, and I've been running at the stiffest setting the whole time. I like it this way. In fact, I prefer stiffer but no one makes anything bigger than a 22mm bar.
If you look at the Swift Springs site, you'll see it's not a matter of larger diameter=better.
Design and wall thickness is the prime concern.
Best one I've seen that actually bothers to explain the design and how it relates to function.
Pity they've not got one for the TSX yet.
Bye TSX, hello domestic?
marcelft
07-10-2018 06:17 PM
k6biv
09-10-2015 06:37 PM
