Pirelli P Zero Nero M+S sizing question...
Old 04-19-2004 | 10:57 AM
gpsiir's Avatar
Looking to replace my tires sometime in the future, and I don't have a desire to buy 18" or 19" rims. I like the P Zero Nero M+S tires, and have read a lot of good things on them. Problem is they don't make a 215 50/17 size. So, size choices are: 215/45WR17 , 225/45WR17, or 235/45WR17. The 215-45 would be same width (of course), but about .4 inches shorter, and giving an overall circumference of 96% of the 215 50/17's. The 225's would be .3 inches, but .39 inches wider, and 98% of the correct circumference. The 235's are almost the same height and circumference (within 99.4%), but about .8 inches wider. I think the width would be the problem, correct? So any of the above work, or should I give up on the P Zero Nero M+S tires..... BTW, I've read all of the posts I could in this section on sizing, they were a help, but I couldn't really tell what width limitations are.... I know that the primary issue with the shorter tires is your spedometer would be off, by 2-4 percent...
Old 04-19-2004 | 12:38 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Most peope have been going with 225/45/17.
And your math is a bit off. The 215/45/17 are about 0.85inches shorter.
I also think that 235 is a bit too wide, although people have done it.
Old 04-19-2004 | 09:35 PM
gpsiir's Avatar
You're correct, the height numbers I gave are compared from the rim to the tire edge and I was thinking of how much height is subtracted from the ground clearance. The actual tire height affect would be double. I think the circumference numbers are correct. I'm adverse to the 235's if it would be dangerous/void warranties/etc. Also, I don't know what the extra width would do to the gas mileage. Suppose the ideal solution would be to talk Pirelli into making the correct size
Old 04-20-2004 | 12:07 AM
Registered AssHat
LikeI said, most people are happy with the 225/45/17, if it does create a but more wheel gap.
Old 04-20-2004 | 09:01 AM
Sturm's Avatar
TSX Bronco
I'm waiting on some wheels from Discount Tire and I went with the Pirelli P-Zero Nero M+S in 225/45/17. Like Lung said, that's what most people are going with. You should be fine with that. I can't wait to get them with the wheels. Too bad I have to wait 5 weeks for my wheels!
hrothgar02
11-02-2015 01:29 PM
ExcelerateRep
10-14-2015 08:20 AM
Tribalheads
09-29-2015 03:24 PM
Birdflunuggetz
ILX
09-28-2015 01:14 PM
dirleton
09-25-2015 12:25 AM
Quick Reply: Pirelli P Zero Nero M+S sizing question...
