pics of 245/40/18
Old 01-12-2010, 07:37 PM
sandman13's Avatar
pics of 245/40/18
has anyone run 245/40/18 on a 18x8.5+48?? will that affect handling or is 235/40 a better option? please post pics if possible.
Old 01-13-2010, 09:20 AM
Old Guy
Simba91102's Avatar
The fit would most likely depend on if and how much you're lowered. The 235/40x18 is the direct replacement size (plus 1) for the OE size 215/50x17 (meaning it's the same diameter). The larger tire would raise your effective final drive ratio (that means lower numerically) and would also be slightly heavier (how much would depend on the tire though). But the wheel would probably be a good fit and you could run the smaller tire on them if you wanted to (the 235/40x18 would actually probably look pretty good).
Old 01-14-2010, 10:07 AM
sandman13's Avatar
I'm dropped a little over an inch all around on tein htechs. I like the meaty look of the 245/40 but not if it's gonna rub...
Old 01-14-2010, 10:19 AM
I used to own a
RedAggie03's Avatar
you're good. That's the right size tire for a 8.5" wheel. The 8.5" Aspec wheels are +45 and most run 245/40/18's and some even run 255/35/18's.
Old 01-19-2010, 02:10 AM
sandman13's Avatar
Yes,...but I'll be running this set-up on a TSX, not a TL. I'm assuming there's a difference b/ween the two as far as fitment/clearance is concerned. I don't think think I'd be able to run a 255 on a TSX.
Old 01-19-2010, 12:17 PM
Old Guy
Simba91102's Avatar
You may get opinions all over the place. I used to run OE TL wheels (the 17x8 et45 variety from the model year 04-08 TL) w/ the TL OE size tire (235/45x17)(they're the same diameter as the TSX OE tire by the way) and I would occasionally rub in back. I'm lowered about an inch. Now I've read posts here from plenty of guys who are as low or lower than me and run a more aggresive setup without rubbing. Are they full of crap? I'm reluctant to say so..... but, I never considered "rubbing" to be a relative word (two people, two opinions), so maybe I'm missing something. My point is that I'm not sure you're going to get a definitive answer to your questions here. Pictures?... maybe.
Old 01-19-2010, 01:23 PM
sandman13's Avatar
I think I'm gonna play it safe & go with 235/40. Seems like the best option for my drop. Hopefully it won't rub.
Old 06-14-2019, 03:31 PM
Jayden Paul's Avatar
Thumbs down
How did the 235/40 go ? did they rub ?
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: pics of 245/40/18
