oversteer and understeer. Clear it up.
can someone give me a quick and easy explanation in lamen's terms on whats the difference between oversteer and understeer?
Photography Nerd
Understeer is when the front end pushes around a corner. As the name implies, it's not steering as much as you'd like.
Oversteer is when the car's rear end over-rotates around a corner, like when you watch drift events.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
no, a better suspension will mean that the handling limits are much higher, ie. you can go much faster around a particular corner before the front end starts drifting out. if you are good, and you know your cars handling limits, you can however drift in a four wheel skid through a corner (even with a front wheel drive car). i don't recommend doing this because the likelihood is that: a) you will loose control of your car, drive off the road, wreck your car and yourself, or b) you will loose control of your car, drive into one or more other cars, wreck your car and their cars, and wreck them and yourself. Leave this to the race track. (and yes, i know it is a hell of a lot easier to do this with rearwheel drive car, than a front wheel drive car; now, if i could only figure out how to do a really good bootleggers turn in a front wheel driv car...). jps
Bye TSX, hello domestic?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
A tighter suspesnion is harder to quantify, but things like preventing body roll and unnecessary weight transfer can help. For example, if you have adjustable shocks, you could make the rears very very stiff and keep the fronts normal, this would cause less weight to be transferred to the rear, and make it easier to oversteer/not-understeer. Tire pressures can be used to do the same, some FWD autocrossers will pump up air pressure to 50-60psi in the rear so that the tires barely have any contact patch.
you can always tune your suspension to counteract over/understeer. There's only so much you can do w/ the FWD platform and a heavy car, but its possible to make it better.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Originally Posted by CGTSX2004
![Huh](https://acurazine.com/forums/images/smilies/huh.gif)
Next month, I'll find out how my TSX will handle on a road course.
Originally Posted by vwong
No long story. Just my auto-x experience when the car was bone stock. I only auto-x'ed the TSX twice. My first run at both times, the car understeered way too much. But it was obvious that I was driving way too aggressive. I then calmed myself down, and drove a lot smoother and the car turned better but still understeered. I blamed that on the damn stock Michelins. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Next month, I'll find out how my TSX will handle on a road course.![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Do share with us your impressions, especially with the mods that you have done. And yes, the Michelin tires are terrible. I can't wait till I get rid of mine in August or September.
Ok, completely clear to me now. Thanks for the responses. Now im curious to try out different dampening settings and changing the tire pressure like xizor said. Right now i have my front shocks more stiff than my rears. i also believe me rear tires are about 2-3 psi lower than my fronts. I'll try it out today and see if i notice some difference. Thanks guys.
Top notch 6MT
Originally Posted by DEVO
most if not all car manufacturers purposely dial in understeer because it's safe to get out of... just let off the gas in a corner... the car corrects itself.
Top notch 6MT
Originally Posted by BlackAc036
Now that I understand what it is, what is the best solution to prevent it on the TSX?
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
335i, 335xi, acura, bmw, dialing, oversteer, oversteering, psi, reduce, suspension, tsx, understeer, understeering
