offset calculator
Audi Driving Snob
offset calculator
For those having trouble conceptualizing how offset works just input the stat and it will tell you what kind of spacing changeyou will have....
http://toy4two.home.mindspring.com/offset.html
3rd Gear
![](http://www.discounttiredirect.com/images/wheel.offset.gif)
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or “deep dish”.
![](http://www.discounttiredirect.com/images/cautionsymbol.jpeg)
That offset calculator doesn't seem to work. Here's another wheel offset calculator
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
spoiler900
10-10-2015 06:48 PM
