ingalls rear camber kit
Does anybody have pics of the ingalls rear camber kit installed on their car? I am not sure as to how the arms are oriented. Mind you they should only fit one way but does it really matter which way the chrome/black lock nuts are installed? How long did it take to adjust the alignment angles to bring it all into spec?
Thanks!
Thanks!
I had mine put on by a mechanic, because I tried for hours and failed to remove the stock hardware (it seemed to have rusted itself into one big piece). In fact, they ended up just flame cutting the stock hardware off. I can take pictures tomorrow and post them here for you, but I think they used their own hardware. Pictures tomorrow.
As for the time to adjust the angles, you should really bring it to an alignment shop to do this, unless you have your own equipment... The damn multi-link rear on the TSX is particularly hard to adjust because of the toe and camber dependency (you can't adjust one without it affecting the other). It took Midas the normal time (about 2 hours from drop off to pick up, longer if there is a wait time, worst case) to adjust it all into spec.
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
