Ingalls Front camber kit
Hey guys,
What tools will I need to install the Ingalls front camber ball-joint kit?
I have a set of pickle forks (ball joint separators) and I have the normal jacks/jack stands and what not.
Do I need to remove the spring and shock assembly?
The directions tell me to remove the upper control arm, is that really needed? I think I read somewhere that you could get away without doing that.
What should I use to press the new ball-joint in?
Is there anything specific that I should look out for when I am installing this?
Thanks,
Thanks,
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
