Ingalls camber kit question
Hi all,
Just purchased this kit for the rear. I know this kit comes with 2 arms: one for adjusting the toe and one for adjusting the camber.
Since the stock toe adjustment is more than enough, can i NOT install the "lower rear link" and just install the "centre lower link" arm to adjust the camber?
will there be any harm to do this or both arm needs to be installed in order to work ?
TIA
TIA
Getting the rear camber back into factory specs will also change toe angle; so much so that the factory toe arm can't accomplish, thus needing the after market toe arm.
I have another question regarding the Ingalls rear camber kit. European accord (tsx) has the headlight adjustment system connected to one of the rear arms (the one most back). Doesn´t TSX have the same "headlight adjustment"system? At the moment when I would install the new arms, I would have no place to connect this "sensor" to which would mean, that the headlights would not adjust while taking more people on bord or vice versa.
JDM Addict
the TSX has no auto leveling headlight features.
BoricuaTL
04-08-2016 01:08 PM
nuldabz
09-03-2015 05:49 PM
