help - tein coilovers noise
Can anyone tell me were the Thread is to help me from not driving my car off a cliff.... My F...ing tein coil-over will not stop make noise but only in the rear.. please help (2004 tsx)
Can you be more descriptive?
What kind of noise? When does it occur?
These three links might help you.
https://acurazine.com/forums/showthr...ght=tein+noise
whats up guys thanks for all the HELP.. here is what i have 04 tsx with tein coilovers they have been on my ride for about 30k now and just about the past 2 week the rear springs have been makeing a squeaking noise. ppl tell me its the weather bc its cold as balls in NY right now....what do you think.
i think i have no idea if you have a tein basic, SS, flex, or CS setup. Assuming basic or SS.
With that assumption, and what little other help you've provided, the noise could be from the OEM hats squeaking against the frame, or squeaky springs that might need some lube, it could be squeaking where the spring hits the hat. I think thats fairly common on the Teins. I had it once on my set, hit it with some oil, and it went away.
yea sorry about that i have the tein basic. And it only makes the sound in the passenger rear hummm its the same for you...? So i'am going to take it to my boys shop friday after noon and lube her up i guess and clean out the snow
my tein basics have been making kind of a honking noise for.... a few months now. i've just learned to live with it. it's kind of a metal rubbing metal noise. or metal rubbing hard rubber. but it's not a grinding sound.
where is my garage?!
1 Post
resurrection!
i've been noticing the last few days that i'm getting some noise in the back right. it's kind of like a rubbing/squeaky noise with my tein basics. i've had them on for about a few thousand miles now (roughly 3-4K), and never noticed it until now. probably b/c i always have music on.
today, i tried to narrow down the conditions as to when i happens. it seems like it only occurs during slower speeds when i drive locally (30mph or less) while going over small bumps and such.
at faster speeds or on level, smooth road, there is no noise.
i kept eyeing the external temp gauge on my MID also, b/c i recall reading that sometimes the noise goes away when it gets warmer. incidentally, the noise was around when the temp was under 70, then seemed to disappear on my way home from the gym when it was over 70.
it'd definately not a clunk or click like some other posters have mentioned. while annoying, i guess i can live with it. but i guess as a safety measure, i probably should have a look-see to make sure everything is ok.
Former Sponsor
Faint squeaking, that comes and goes, is probably one of two things:
Air bubbles moving in and out of the shock piston (kinda like how a squirt bottle squeaks when you are blowing air). Or it could be the shaft rubbing on the seal on shock.
Can't do much about the air bubbles. But to get rid of the squeak you can try applying some light wet silicone spray to the shock shaft where it enters the damper. I have heard more than a few people saw this was a good fix.
Clunking, clanking, rubbing, bonking, boinking, grinding, etc....anything besides a mild, quiet, intermittent squeak IS NOT NORMAL. Something got messed up in the install and it needs to be rechecked!
It could be a lot of different things. Incorrect washer order on the hat assembly, loose sway bar endlink (which can be avoided with Fsatline Powerlinks ), improper spring alignment, etc....
I feel like requesting a stick. How many times has the question of Tein noise come up? The answer is always the same. We don't know what your clunk is without pics, or even physically looking at it.
Marcus
Marcus
Former Sponsor
Originally Posted by mclovintsx
So I'm guessing this is a fairly common problem with tein basics. Does anybody know if the buddy clubs N+ has common problems as well?
Check it out, there is no PROBLEM with the Teins. It is more of an attribute. I've heard lots of shocks squeak, not just the occasion Tein observation.
The N+ is a monotube, and as such it has a different design than the SS/Basics. Same as the Monoflex, monotubes are not prone to getting air bubbles like the twin tubes are.
Marcus
Thanks!
are you talking about left to right or top to bottom? when I jack the front end up, I am able to spin the springs freely left or right since there is no load on them. I am wondering if the springs should be facing a certain way.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
