Has anyone installed the Neuspeed front sway bar?
If so, what are your impressions? I'm thinking of getting it myself, but I noticed that it's only .5mm thicker than the stock one. Some say that because the Neuspeed comes with poly bushings, it should be an improvement over stock. I already have the Comptech rear sway. Informed responses are welcome.
I've heard that, too. Lubing the bushings supposedly diminishes the noise. I'd tolerate some squeaking for less body roll/improved cornering.
As far as I can tell, Neuspeed is the only company offering a front sway for the TSX. And having searched the forums, I can't find one person who's installed it. Anyone?
The front bar is not as easy to install as the rear bar. It requires removing the lower sub-frame to get to the D-bushings. Since there's isn't a big difference in bar dia. I would just install poly bushing to the stock bar instead. Also, keep in mind a larger bar can increase understeer.
