Good deal for a set of rims for winter tires. Post here.
Ok guys, what do you suggest for a 4 set rims to use with winter tires. Something not expensive? Any good deals that you know about.
Post here.
Post here.
J M U ... DUUUKEESSSS
just look for another set of OEM wheels off the black market or ebay, those should be pretty cheap.
Or try tirerack.com and find a set on sale that'll fit a TSX.
I personally don't see a need in spending too much money on a set of winter wheels
I used a set of 16" wheels off a Mazda (I think it was off a Miata). Same offset and bolt pattern. Fits but the front brake clearance is VERY close. That's probably the only thing you'd want to check if you do go 16"
looks like you can't get the steelies on tirerack for the tsx right now (at least not when i configure a package for my '07). might get some cheapo alloys instead, any other good deals out there?
is there any problem with having a set of winters without the TPMS in the wheel, like does something beep annoyingly or is there a flashing light. if so can you easily disable it?
So far I put these on my wish list on tirerack, $730 shipped. I haven't made a decision:
Continental ExtremeWinterContact (Studless Ice & Snow)
205/60R16 XL. T Speed Rated
Elbrus I05 Silver Machined w/Ice Coating (4) 16X7.5
Thoughts on
General Altimax Arctic (Studdable Winter/Snow)
Matched with these rims
Sport Edition D3
http://www.tirerack.com/wheels/Wheel...ed&showRear=no
Offset: 53mm
Backspacing: 6.14
"Bolt Pattern: 5-114
Rec. Tire Size: 205/60-16
Weight: 17.0lbs.
Sport Edition D3
Offset: 53mm
Backspacing: 6.14
Weight: 17.0lbs.
New wheels on and snowing here in MN, love the Blizzak's already. Any idea why my TPMS sensors are not warning me? I did not purchase new ones with the new wheels. Even when i click through it says my tire pressure is ok at all 4 corners. Strange?
nuldabz
09-03-2015 05:49 PM
