Going lower on A spec struts????
I put on the A spec kit last week and i like the ride and handling upgrade but eventually when i get wheels i'll probably want to go lower. Anybody swapped the A spec springs for something like the Pro-Kit?
Don't do it.......
When you're ready to switch, there's always people looking for used A-Spec kits. Sell it and pick a complete package. You still have a nice balanced package right now; you'll be taking a step back by simply adding springs to your kit.
I know some people have speculated that it would be okay because the A-Spec struts are designed for lower springs, but they're still not properly matched/tuned to some random spring, and because they have no damping adjustability, they don't have any flexibility in that regard.
I know the Koni setup may not be a perfect match for everyone, because Koni does not know what spring you will be using either, but you can adjust the damping to your tastes/needs to work better with your springs.
Or consider an all-in-one coilover setup....
I want the Eibach Pro-System and rear camber kit but last time i checked it will be a while before they get the struts ready. I'll just run the A spec until its available.
Yeah their supplier(who they wouldn't name, probably Bilstein or Tokico) is having trouble with the struts. I trust Eibach though and they won't release it until it's right.
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 07:42 PM
