Front Sway Bar 26.5mm thick
Got Milk???
Quick question for you suspension experts, I did a search on the front sway bar for the TSX, it's at 26.5mm thick. Wouldn't it make the TSX handle a lot more neutral to have the same thickness sway bar in the rear or even thicker? What are the downsides to that though?
KC
KC
Actually, I think it is 25.4mm and the stiffer the rear, the more likely that it will bust out on you... not something you'd want for the general population to have, which is why I'm guessing that they put as small a sway bar as they did OEM on the rear.
Bye TSX, hello domestic?
KC
KC
Got Milk???
I was thinking about the same, thicker in the rear, more neutral? But for some reason, I'm wondering if going too thick in the rear will actually be bad for handling? Even with thicker RSB, I don't see a FWD oversteering too much to be dangerous though...
KC
KC
Someone stole "My Garage"
KC
KC
Perfect handling is almost always seen as being neutral with a hint of oversteer. Not oversteer-as-much-as-possible.
marcelft
07-10-2018 06:17 PM
k6biv
09-10-2015 06:37 PM
