Front camber kit?
Front camber kit?
Hey all, I have been searching for a set of front camber kit and all i've found is the one from Comptech and Progress. My question is how is the quality on these camber kit.
If I remember correctly they are offset cam joint type?
I'm a noob when it comes to suspension so i'll need some clarification.
What about camber plates? Can I use that up front?
Ideally i'd like an adjustable A arm like VWong's but they're just too expensive.
Well, I believe both Progress and Comptech use SPC's front camber kit. All front camber kits are going to be the adjustable ball type unless you got with Spoon's upper arm, which is $$$ and only gives you more negative. Ingall also has an upper ball joint too. I don't think many ppl here have done front camber kits b/c unless you have an extreme drop, it doesn't change your camber much.
Here are the part numbers for the SPC and Ingall kits (~$139 USD for a front kit):
SPC 65210
Ingalls 35590
SPC 65210
Ingalls 35590
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
