EXCELERATE PERFORMANCE: Last Chance for Koni's Sale - 3 SETS IN STOCK!!!
Old 05-25-2011 | 02:06 PM
ExcelerateRep's Avatar
Former Sponsor
This is a Special Acurazine Pricing Event for the Koni "Yellow" Sport Shocks. If you are interested in any other Koni products PM me. This sale will last till May 31st 2011.
The Koni Sport product line is one of our specialities. Koni serves Sporting Drivers with a carefully designed range of sport shock absorbers. This product focuses on exceptional road holding and handling, combined with a reasonable level of driving comfort. They can also be used with spring kits to lower a vehicle up to 35mm.
Many of the Koni Sport dampers are externally adjustable by means of an adjustment knob at the top of the damper. This means you do not have to remove the damper from the vehicle to adjust the rebound forces. This enables you to fine tune the handling & ride to suit your driving style.
Dampers without the top adjustable feature can still be adjusted, although they will need to be removed from the vehicle to achieve this. You may wish to use lowered springs with the Koni Sport range, if you do this please be aware the maximum lowering permitted is 35mm. Please also ensure that any bump stops are re-fitted to ensure no damage occurs to the valving should the damper bottom out.
KONI "YELLOW" SPORT SHOCK
Features
* Big handling improvements
* Reasonable ride quality
* External rebound adjustment on most cars
* Best KONI shock for all lowering springs
* Re-buildable and re-valveable for custom vehicle setups
* Yellow exterior finish
* Lifetime Warranty
The website already reflects the discounted price, there is no promo code. Each shock is sold individually.
Click on the following link to find KONI Yellows for your Acura TSX:
Front Left Shock:
http://store.excelerateperformance.c.../i-100677.aspx
Front Right Shock:
http://store.excelerateperformance.c.../i-105385.aspx
Rear Shocks (Order a Quantity of 2):
http://store.excelerateperformance.c...?itemid=105386
Old 05-25-2011 | 03:35 PM
RZANYS2K's Avatar
how much shipped to 11577?
Old 05-26-2011 | 01:03 PM
Excelerate's Avatar
Former Sponsor
Use the links in the first post. You need 1 of each of the front shocks (there is a left and right) and 2 of the rear shocks.
Add to cart and then put in your zip code for a shipping quote; shipping should be around $30 to your zip code.
jblessing
08-08-2018 10:43 PM
james357
02-13-2016 03:37 PM
o8 ENVII 8o
11-30-2015 05:23 PM
JnC
09-11-2015 07:06 AM
braveheart
09-07-2015 09:12 AM
Quick Reply: EXCELERATE PERFORMANCE: Last Chance for Koni's Sale - 3 SETS IN STOCK!!!
