Dropzone Coilovers Conversion Kit with Springs
Can anyone explain how these kits work? It states it can be used with the stock shocks/struts. Is there any modification required to fit on stock oem parts?
Has anyone used dropzone for acura tsx 2004-2008? experiences?
![](http://www.sciontist.com/products/dropzone_coilovers.jpg)
I wouldn't suggest using these types of coilovers for your TSX. If you're looking into sleeve-type coilovers, why don't you look into some Ground Control coilovers? The reason I wouldn't recommend these coilovers is because they're an "e-Bay"/AutoZone company and they probably don't do much R&D. You're getting what you pay for...
The Dropzone coilovers you have there, replace the stock springs on your stock strut.
Can you be a little more specific about how they work? See how the bottom of the body are threaded? The higher up you move the rings on the thread, the higher you would be raising your car. As seen in the picture, they're at the lowest setting.
What do you mean by R&D? I looked at Ground Control however I do not see it for my year 2008 TSX only 2004-2006?
R&D - Research and development.
I would call Ground Control directly. What's your budget? Are you willing to sacrifice ride comfort to save a couple bucks? Do some research, hit the search button.
oh ok...I don't want to spend alot nor more than $300 or so, I want a 1.5 drop all the way around. I want a simple set up with a stock like feel...I was originally going just get lowering springs tanabe NF210 1.5 inch drop to maintain similar stock feel with oem shocks/struts my car is only a year old....let me know
Check: www.heeltoeauto.com
In that case, I would STRONGLY suggest springs. I've heard a lot of great things about Tanabe springs. I'm running Tanabe coilovers right now and I love them. Other spring manufacture's you might want to look into: Tein, Comptech, and Progress.
Is it ok to just run the Lowering Sport Spring - Normal Feeling SUSTEC - Tanabe NF210 on stock shock/strut?
It is not suggested to use aftermarket springs (like the Tanabe NF210) on stock struts because it supposidely decreases the life of the strut. I've used aftermarket springs on stock struts and I haven't had a problem. I'd say pick up the springs and have a shop install them for about $100, get an alignment ($60-75) and you're good to go!
I hope that wasn't all confusing...
Time to Climb
you're stock shocks won't last too long if you use an aftermarket spring with 1.5" or greater drop. oem shock life varies based on driving style/habits, conditions, abuse, aftermarket componentry, etc. with that said, you can get by with just springs for right now, but the shocks will have to be replaced down the road.
to my knowledge, the tein h-tech and the oem a-spec springs would be your best best without having to replace the shocks. but, then again, they offer less than an inch for drop
"Normal Feeling is for those who wish to lower their vehicle, while maintaining the comfort of the stock suspension.
Tanabe NF210 lowers the vehicle an average of 1 1/4~1 1/2in (30~40mm) without sacrificing the stock ride quality.
This is achieved by raising the spring rate no more than 5%
The stifness of this spring is 5% more than OEM. Regardless any shock will have to be replaced, they say usually replaced by 50,000 miles...How can this spring cause premature failure to the stock shocks when its only 5% difference?
Time to Climb
simple, oem shocks were designed for an oem ride height.
the tanabe springs are a good choice and many tsxers are runnin it. just note that your shocks will fail quicker than if riding on oem springs
best of luck,
vinny
best of luck,
vinny
I may be the abnormal case, but I've been running Comptech 110-155 springs (from the TL) for at least 70k miles on the OEM shocks. 1" drop, spirited driver, no shock issues at all. There were quite a few folks that went after the TSX specific springs (1.5" drop) when they were released and some had issues blowing shocks. If you want your car lowered, I highly suggest you save your money and do the right thing as mentioned by a few here. One risk of modifying stock components is early failure.
what is better of the two i am stock on either tein s w/ stock shocks or tanable nf210 w/ stock shocks?
1fatcrxnem1
22
06-01-2018 01:23 AM
BoricuaTL
04-08-2016 01:08 PM
4drviper
09-23-2015 07:42 PM
