Difference in height between various perch settings (koni/eiback pro) ?
I was wondering what the height differences were between the various perch settings on the Neuspeed Koni shocks and Eibach springs. I have seen pictures with various settings, but never directly compared to one another. I was wondering what the difference between a 0 setting compared to a 1 setting was? 1/2", 1/4" ? Are the settings in equal increments? So say if the setting between each increment were 1/4", and I went from a 1 to a -1 setting, the total drop would be 1/2". I was just curious as I was thinking about getting this setup, and wanted to know how flexible it was in terms of the amount of drop you could dial in.
1 Post
Check out these 2 posts:
https://acurazine.com/forums/showthread.php?t=30458
https://acurazine.com/forums/showthread.php?t=30514
What I observed on Neuspeed Konis with Eibach Pro Kits:
Perch setting (front)
0 (middle) = height at 25 3/4"
-2 (lowest) = height at 24 3/4"
I would assume that perch setting -1 would be at 25 1/4" so basically, 1/2 inch change from perch setting to perch setting on Neuspeed Konis which have 5 perch settings choices.
1fatcrxnem1
22
06-01-2018 01:23 AM
09-14-2015 10:48 AM
braveheart
09-07-2015 08:12 AM
