Convert spring rates
Can someone please convert these spring rates: 400 (front) and 225 (rear). I'm used to seeing spring rates, for example, in the format of 10 (front) and 8 (rear). I'm assuming my numbers are based on lbs/inch as opposed to kg/mm. Thanks.
To convert from SI unit (kg/mm) to English unit (lbs/in), multiply 55.88.
Divided by 55.88 if you want to go the other way. So in your case, it's 7.16 kg/mm front, 4.03 kg/mm rear.
Fear the TrolFkr
http://www.zilvia.net/faqs/archive/springrates.asp
Although this is probably more precise:
http://www.onlineconversion.com/foru...1110951659.htm
If we use 56, that means 400/56 and 225/56 = 7.14F / 4.01R.
I'm not sure if these values are supposed to be rounded to a whole number or if it's customary to go to 2 decimal positions (or maybe only 1 decimal position?).
Fear the TrolFkr
BTW, if you're running Windows and want a nice little utility to handle other types of basic convertions, this is what I use:
http://www.joshmadison.com/software/convert/
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
