Comptech RSB Installed
Fear the TrolFkr
I installed my Comptech RSB yesterday about 3 weeks after installing Tein SS. Wow, what a difference. I loved the way the car handled after the Teins but I love it even more now. I wasn't expecting it to be so noticable even though that's exactly what many people seem to report.
It took about 3 hours from the time I pulled into the garage to the time I left to go home, but that included time to re-torque all the bolts from the tein/ingalls install on the front and back. That also included the 10-15 min ride I took to let the RSB settle in, then the time it took to jack it back up and re-torque the RSB bolts It also took me about 5 mins (which seemed like an hour) just to get the RSB into position because I mistakenly tried to fit it in with the ES poly bushings on.
I also set the tire pressure to 32f/30r. I feel that 3 hours for all that is reasonable. And if didn't hurt having this thread available.
Here are a couple pics of the RSB and ES poly bushings:
![](http://home.ptd.net/~rmirro/TSX/tsx-comptech-2.jpg)
![](http://home.ptd.net/~rmirro/TSX/tsx-comptech-4.jpg)
![](http://home.ptd.net/~rmirro/TSX/tsx-comptech-3.jpg)
![](http://home.ptd.net/~rmirro/TSX/tsx-comptech-1.jpg)
Sorry to be going off topic here but seeing that you're running the same setup I am right now do you notice that the suspension is now exhibiting more noise over certain bumps at all?
By the way what's the torque for the upper mounts you used?
I guess he brings a little too much of his christmas spirit to the suspension.
Notice how his camber kit is in the same red paint.
Damn! it matches well with TEIN green.
Fear the TrolFkr
Originally Posted by Tsx536
Your Comptech Rear Sway Bar is red?
Fear the TrolFkr
Originally Posted by mg7726
hey - at least you didn't paint the rotors too! ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
nice red/green christmas colors![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Fear the TrolFkr
I did massively bottom out over a speed bump a couple days after installing the Teins, so maybe I damaged something related to steering the car since the noise is sort of a knocking sound.
As for the RSB torques, I used my service manual to determine them. The 4 bushing clamp bolts are 16 lbs-ft and the 2 endlink bolts are 28 lbs-ft.
BTW, I originally chose the red paint because my car is red. I figured it wasn't such a bad thing to have the mods I installed stick out a little from the rest of the car. I don't know, maybe it's a lame idea.
HEY, about the red paint -- might as well show off your mods.
Can you see this stuff from behind the car? I have seen photos of chrome lower-rear-strut bars that probably looked nice if you had a low angle. And I like those blue front lower strut bars (posted elsewhere), except I don't like how low they are to the ground. But, hey, at least they LOOK good, and that's what counts! ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I like red-painted calipers too, but if they are otherwise stock, yeah, it does sound a bit wanna-be-ish. Then again, it's not like a lot of the crazy stuff people do to their cars. I say go for it. (I have read that you have to use special paint for the calipers. I'd probably find some way to screw it up, so I think I'll pass, but I like the idea. :-) )
I also have sway bar (Progress) installed over the weekend. Wow, it really made a difference especially in corners, off ramps and twisty roads. Turns are more neutral and gives me more confidence in curve roads (at higher speed). I must say, that all you guys' comments and reviews made me do this mod. Thanks peeps.
Now, I'm thinking of getting a coilover.
Fear the TrolFkr
BoricuaTL
04-08-2016 01:08 PM
k6biv
09-10-2015 06:37 PM
