Can a 04 TL Rim fit a 06 TSX?
If you're stock height, they should fit no problem. They're wider (17x8 versus the TSX OE 17x7) and they have less offset (45 versus 55 for the TSX wheels), but that's OK. The OE TL size tire (235/45x17) should fit OK and is the same height as the TSX OE size (215/50x17). But..... I had trouble with a slight rub in back cause I'm lowered, though not that bad or that often. They're a pretty common swap here and there are allot of different opinions on fit. This is mine (and I actually did run them for a while)
acura_dipset_tl
01-01-2016 03:02 PM
nuldabz
09-03-2015 05:49 PM
