Buddy Club N+ Spec Review and Installed Pics
*Note: Let me start off by reminding everyone that I had the Tanabe Sustec Pro-OC Type II's on the car before this.
Important Install Note: The way these came from the factory, when I first took them out of the box, seemed to be extremely low when I compared them to my already lowered Tanabe's. So I lenghtened the fronts by half an inch before I installed them. After I installed them and put the car down they were still insanely low. So low that I couldn't get the jack out from under the car. I had to put the car down on blocks just to get the jack out and then I had to adjust them right then otherwise I think I would have rubbed if I hit a snail, the tires were tucked at least 1-1.5 inches. So I would strongly reccomend lengthening them significantly before the install. Other then that the install was really straight forward, a big thanks to xizor for helping me out!
Driving Impression:*Remember above note above* Good stuff; they are much more performance oriented then the Tanabes. It is a huge improvment in the corners and that's def worth
Bad stuff; I slightly miss my Tanabe's already. I had to take the car into downtown Washington and it was rough. I am probably biased because I had the other coilovers on but these are much more harsh then those. I still need to play around with the dampening though so hopefully I will be able to improve the ride. All in all though, if you want performance you will not be happy with the Tanabe's and these are probably a good choice. On the other hand, if drive comfort was your #1, then these are NOT a good choice for you.
My rating... 7.5/10
Installed Pics:
My rating... 7.5/10
Installed Pics:
Originally Posted by ΤΟΜΜ。
Thank you for the great review!
You are giving 7.5/10 for N+?hm..what would you give for the Tanabe's?
(Does Tanabe improve in handling significantly than stock suspension?)
Originally Posted by marketman
What dampening settings did you start with? I am switching over from Pro-kit with stock shocks - I was hopeful that ride would be as good or better - am I going to be disappointed??
what do you want? If you are looking for ride quality you *might* be dissapointed. I'm not 100% sure, never been in a car with prokit and stock shocks. Also, I have realized that ride quality is hugely subjective, so you will have to wait and see.If you wanted ride quality though, I would def suggest the Tananbe's.
by the way man they look really good. no install pics though.
And no, no install pics sorry... lol I wanted to take a pic when it was insanely low though, just for fun
Originally Posted by jiggaman
good review Fury, I am loving the Tanabes, the perform better than the pro kit spring combo Eibach spring AND are more comfortable. I'm all done spending money on my suspension.
Originally Posted by JDMculture
fury.. nice!!!
I told you on your previously post that you had to lengthing the perches =P
Originally Posted by vwong
Just curious, does the Buddy Club come with installation instructions that include the recommended factory settings?
If you're a cracker like me then
What about a diagram/drawing showing the recommended dimensions?
Originally Posted by TSX.Fury
The only thing I could find and understand was there was a diagram for the rear assemblys that showed the body being threaded 20mm into the base. Other then the "20mm" I couldn't understand a single thing on the instructions. There were other diagrams but I couldn't make out anything on them.
And I thought you were a JDM whore, if you were you should be able speak and read Japanese. Learn Japanese kemo sabe, only then you can be a JDM whore!
Marketmen, back then when I had the Eibachs, they are no where close to the BC Racing Specs I got right now both in comfort and performance. To add to that, with the BC coilovers, you get insanely crisp road feel from the steering, I am very pleased.
Like TSX Fury said, if you're looking for comfort over performance, by all means go with Tanabes, Buddy Clubs are meant for performance tuners. I have my Racing Specs tuned to 1 click from softest up front and 2 clicks from softest rear, and the car rides much more compliant than when I had it before at midrange. The ride is still stiff, but much closer to the Tanabes ride feel than before. And I have to point out, steering feel with the Buddy Clubs are just incredible. Part of the reason why it's crisp is because of the upper pillowball mount.
I love your ride TSX Fury, very clean and damn... it's very low too.
Try setting ur shocks to stiffest all around, you'll rip through corners like you're on rails, just not very @$$-friendly
-KC
-KC
KC
Buddy Club TSX - I would love to get an English version of install instructions for The N+ Spec coilovers. Mine should arrive this afternoon and I am going to install myself. Can you e-mail or do you need my address? Thanks again for the offer - from what I can see on this board, and the assistance you have offered to date, BC is fortunate to have you as an employee!
Originally Posted by BuddyClub-TSX
Hi TSX,Fury .. I can sent you the English version manual for you.
I got the height worked out now but I want to make sure the preload is at the correct setting. Thanks a lot
Email is tsx.fury@gmail.com
can you speak japanese
don't tell me you don't either, aren't you in college better take Japanese next semester so you will be able to understnd the intructions on all the JDM parts you gonna get next year and then help Ben translate.
what, they come with english versions? can I please get one too for the Racing Spec coilovers? it's much appreciated
KC
Albert@aaimotorsports.com
Wow that would be awesome man
you still havent answered the questoin can you speak or read japanese or else you are not a real japanese or mugen whore either.
Just sent it to you!
-KC
-KC
but performance wise they are
