215 vs 225 in Yokohama V4S
'04 NBP / Parchment 6MT
Anyone see any advantage in going to the 225/50R17 vs the 215/50R17 tire? Both are available from Yokohama... price difference is negligible... a buck a tire.
I'm told the TSX is 'undertired' and the 225 will provide slightly better traction, cornering grip, braking as there is a larger tread footprint. It only affects the speedo by 1.5%....
Thoughts?
Thoughts?
Time to Climb
i'd go for the 225 series tires. not only for reasons you stated above, but also because the tire is slightly wider, meaning it will help cushion against nasty curb scrubs on your wheels.
Originally Posted by afici0nad0
where are you getting them, and how much?
i wouldn't mind grabbing a set of 225/45/17.
I know because I'm on Yoko ES100s 225/45/17 right now. I definitely prefer the wider tire.
Someone stole "My Garage"
Originally Posted by moda_way
Don't forget, this size is -1.9% of the stock, so your speedo will be slightly off.
Originally Posted by curls
Yeah, but isn't the 225/45-17 the stock size for A-spec wheels? Do they change the speedo from the factory in this case?
Thoughts?
Thoughts?
If you simply get a great performance tire, in the factory size, you should notice a big improvement. I had odometer, and fuel estimate errors in my VW by going "plus 0", as you are suggesting with the wider tire. To truly go "plus 0" you would also get a tire that changes the sidewall to width ratio, (the 45 and 50 literally means 45% and 50% of the width). On the other hand, you can always confirm your speedo by using the GPS unit in your dash.
Originally Posted by TSX2345
so 225/50/17 will fit on the stock rim with no problems?
if gettin new wheels isnt out of the question too....supposedly 17x7.5-8.0
gettin 235/45's would be an even better upgrade. Wider, and matches overall diameter almost perfectly.
just my
just my
John Starks - The Dunk
besides the speedo being slightly off......are there any other cons to getting the 225?
if I go with the 225 series , do I get the 225/50, 225/45, 225/40 ??? Seems like all 3 are being run with the stock rims.
Living the Dream
just my![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
just my
09-17-2015 09:01 PM
nuldabz
09-03-2015 05:49 PM
