18x8 +40 offset, will I rub?
I kAnt Spel guD
Originally Posted by jumpmanbsktbll
....with a drop of around 1.5in?
If you plan to run an 18x8rim I would go no more offset then +45mm, however you may even want to limit the rim to 7.5" wide in this case.
I had to downsize to a +46mm offset rim on my Accord with a 7" wide rim on 225 tires, I now finally no longer rub, ever.
Im running 17x8's with a 43 offset, so Id agree with the above advice,
Heres a good link for understanding the effects of offset:
http://marksink.com/tire_wheel_offset/offset.html
ASM 3G TL Type-S
yes, but as long as hes running the proper tire size, there shouldn't be a difference in the overall diameter between 17x8's and 18x8's, Im also lowered almost 3 inches, with no rubbing
Actually, i've been thinking about this, I'd say you probably could run a 225 width tire on your rim, and manage to make it without rubbing, wheels will poke out of the fenders though.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
