18" or 19" ?
crc
18" or 19" ?
I cant decide if i want to get 18" or 19" rims for my black tsx.... i was wondering if it would look funny if i got 19"s withought lowering my car....with the car really high off the ground.....but if i get 18" its only 1 inch different than the stock rims......cant decide...can you guys share your thoughts?
Got Milk???
18" or 19", it will not affect the height of your ride. Basically, the bigger rims you go with, your tires will look thinner around the rims, keeping the original overall diameter of the wheel. If you get 18's, you might not need to lower it, but 19s, I'd definitely lower to get a clean look.
crc
yea...i think i have my mind set on the marqi 18"s just wanna know if they are good quality rims... http://www.superbuywheels.com/wheel/...&finish=chrome
Photography Nerd
http://www.1010tires.com/hubrings.asp?id2=hubring
The wheels you like have a bigger center hole drilled in them than is required by your hub (73.1mm on the wheel and 64.1mm on the hub). These hub rings fill that space to ensure your wheel is properly aligned on the hub.
Hub centric rings are manufactured so that when they are installed on a vehicle, the wheels are located directly off of the centre flange of the brake drum or rotor. This is done to insure that the outer beads of the wheel are concentric with the wheel bearings. The result is a much truer, better balanced tire/wheel assembly. This is very important with modern high tech suspension systems.
Bye TSX, hello domestic?
Originally Posted by cArKc
What do you guys think of the Marqi MQ18 on yokohama avs dB? are Marqi wheels nice and reliable?
Originally Posted by xizor
never in my life heard of them, so take that w/ a grain of salt (i know a good amount about wheels)
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
ok....squash that idea.....what do you guys think of the 18x8 TSW Kyalami chrome rims?
crc
its gonna look funny if you dont lower it no matter what rim size you have.
and even tho "in theory" your car is supposed to be the same height with bigger tires/smaller wheels (b/c you're supposed to maintain the overall diameter), you wont.
your car will be higher and it will look even funnier than stock. trust me.
![Trout Slap](https://acurazine.com/forums/images/smilies/troutslap.gif)
Photography Nerd
Mr. I-Couldn't-Fit-A-Trout-Under-My-Car-Because-It's-So-Low,
The diameter doesn't change, the bigger wheels just give the illusion that your car is higher. :troutslap
crc
it's gonna me a little more than a month before i make my final decision....i think i will get the 18"s first and see how it looks and if i need to lower it or not.....im guessing eventually i would have to lower it
crc
And you guys heard anything about the MB design wheels?good./bad? i read some reviews on discount tires, seems like its pretty good quality wheels
Originally Posted by Dan Martin
It might if you can find it in a high offset like +55
just go ahead an lift it....i heard that "Rancho" makes a good lift kit for the TSX...
www.GoRancho.com
crc
Anyone heard of Veloche Wheels?? loooking at these 18x7.5 Veloche Vertice 570 wheels, looks nice but not sure about the quality, they run for $200 per wheels (chrome)
www.velochewheels.com
