05 Acura TSX tires
05 Acura TSX tires
My new 05 TSX 6MT with Navi Black/Ebony will be in on the 18th from the factory. I am trying to decide if I should put different tires (wider) on it right when I get it. Anyone have some suggestions on tires to get if I do so, or should I keep the stock tires?
Photography Nerd
I don't recommend putting wider tires on the factory rims, but if you're changing rims then go for it. My next tires will be Fuzion ZRi in 215/50/17 and keeping my stock rims.
I'd buy stock size, but a better compound, to avoid potential issues with flexing sidewalls from wider tires on OE rims. OEM Michelins really suck, so it is still a major improvement and one you can see if you need to improve upon before going full out with new rims etc.
HOWARD911S
you mean mount a wider tire, like 225 or 235 on stock rim? i have tried that before, it does not look so good. the tire bubble out a little bit, and though you may notice improved traction, the steering wheel and whatever they do to tune the tire width and steering feelnig get thrown off. After I tried it, my steering wheel have more plays in them, they feel lighter and have more movement from left to right while driving and especially when u brake. It lacks that on center feel from factory. If you were to do it, get new rims and tires.
HOWEVER! i have tried put new rims and tires. 18 inches with 225 or 235 series tires i forgot. it is better than just putting a fatter tire on stock rim. however, i still got more play and slightly loose that on center feel. though having a new rim and tire package is significantly than just putting a fat tire on the stock wheel.. at the end i just end up putting stock rim and tire back.. though doesnt look as good, but i love that straight, steady on center feel...
HOWARD911S
Photography Nerd
Originally Posted by Bill Hook
Bridgestone, or so I thought.
They're practically a clone of the RE750's. There's a slight variation in tread design but they're nearly identical otherwise, except a lot cheaper.
Performance tires are unlikely to be quieter than all seasons. That being said, my snows are quieter than these michelins so you might get lucky.
Thanks and I love your avatar.
Photography Nerd
Originally Posted by dano2000
thanks-what would it cost roughly to replace them? Finally, would you recommend getting the acura wheel locks for the rims? I think they are $29. If so, would I be able to put them on myself?
The tires go for $88/pc at TireRack and I think most shops will charge $40-$60 for mounting and balancing for the set. So you're probably just over $400 for the set. You can sell your stock rubber and recover most that cost.
Wheel locks are easy to install, they're just a nut that require a keyed socket.
We still don't know if the compound is the same, though.
HOWARD911S
ive always bought my past tires from www.tires.com they have free shipping, and if you are near any dicount tires. check their chain store from web site. they will mount your tire for 5 dollars easy. thats 5 bucks for mount and balancing since you bought tires from their web site. best deal i ever had!
Where and whom do you sell your stock tires to? Also, would you recommend getting the wheel locks or don't bother?
Originally Posted by Howard911s
YO DAN, i been seeing this FUZION tire ad, who makes them? are they summer or all season. any good?
Bridgestone, they are summer tires. For about the same price or a LITTLE more, check out the new KUMHOs line up.
nuldabz
09-03-2015 05:49 PM
