TSX Idle Varies
TSX Idle Varies
Hey guys my 2004 TSX has 64k on it and it has recently started to have an idle problem. Before anyone says it please don't say it is supposed to vary I know that but it shouldn't be doing it like this. It will drop for an instant and then come back. Doing it over and over again. This problem is intermittent and the car runs smooth on the highway. Yesterday it stalled backing out of the driveway. Anyone got suggestions. I am going to replace the spark plugs today. Oh yeah one other thing the dealer is 3 hours away way too far just to run it by for a check up.
Make a hole, coming thru!
Happen only when cold? Or all the time? Anecdotally, I had a bizarre problem with an 82 Accord, barely ran when cold, stalled out, but when warm, ran fine. Turned out there were plastic floats in the whatcha-ma-callit, not brass like other engines, and they were full of gas. Service station guy was aghast. Your problem is certainly different, but reproducibility is a key clue.
Option: is there a Honda dealer closer? They may be able to troubleshoot for your, and determine if an Acura dealer needs to get in there and replace something. Better than buying things and guessing. I did that few times on my Jeep, wasted $.
Check your vacuum hoses too, an air leak can cause idle problems. Eventually you'll probably get a check engine light but if it's part of the emissions system that's causing this it can take awhile to show up. Sometimes codes are stored before a light goes on so take the car to autozone or another local shop that reads the codes for free...you may just get lucky. Otherwise take it to a local mechanic and try to find the cause because randomly throwing parts at a problem will make you go broke quick.
Originally Posted by davidspalding
Happen only when cold? Or all the time? ...
I put in injector cleaner and an octane boost yesterday along with a fresh tank of gas and no problems today. I am going to keep on watching it. I also hooked up a code reader and nothing is reporting.
GWEEDOspeedo
01-15-2016 10:39 PM
DerrickW
11-15-2015 05:52 PM
