Slight clicking sound???!
Hey guys I have been searching but I have a question. When I drive my car it sounds a tad rough when idling and when I am going from first to 2nd it makes this clicking sound around 2-3500k RPM's. Just wanted to know if I should have it looked at or can someone possibly help me with this problem? Other than that the car runs fine. Any help or expertise would be appreciated!! THanks guys!!
Originally Posted by Alin10123
That sounds like the timing chain. Our TSX's use a timing chain instead of a belt. This way it's pretty much maintenance free and less chance of it breaking.
The only timing chain I ever done was an LT5 engine (corvette engine) and you have to rip out a bunch of stuff to get to it (I'm talking about the entire pulley system, water pump, oil pump, etc.) but once you get to it, it much easier to put on than a belt (at least that's what I think).
Originally Posted by goddsmack
uh, yeah...umm, I'm going to have to disagree with you on that point. Timing chains needs also maintenance as the links do tend to wear also and they can break just as well also. The good thing about chains is that they are stronger (so you don't have to change them as often as a belt), retain their position as far as timing (belts tend to stretch over time and their tension as a result can loosen up), and they won't skip teeth like a belt can (previous point only to add that if the tensioner isn't properly functioning and the belt stretches, it will jump teeth and two-three teeth off is enough to cause problems). The unfortunate thing is as you mentioned above, they are noiser than a belt (they ratttle sort of speak) and I think, not sure about this point, but they tend to make an engine vibrate more than usual, this is especially promanent in bigger engines. Chains are also more expensive to manufactor, develop, and service... versus belts which are generally cheaper to purchase and conduct labor on.
Notice i used the words "pretty much" and i also said "less chance of breaking". I Never said that it wouldn't break and didn't require ANY mainteance. But most of us, if we're not keeping a car well past the first scheduled maintenance, will not have to worry about replacing of the chains.
So guys do you think I should go get it checked out????
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
