Rear suspension squeaking...
Just dial 1911
1 Post
Hey guys...I finally got around to installing poly bushings for my CT sway. For a few weeks now, I've had a squeak in the rear suspension. I just figured it was the sway and just waited till today to fix it. But, after installing the new bushings, I still have the same squeak.
Its coming from the passenger side rear, and if I just push down a few times on the car I can hear it. The only other mod I have back there are the Tein's, but I really dont think this sound is coming from them. So I'm guessing its comming from one of the links? Any ideas on what might need to be lubed and where?
I had a similar problem with my 05 TSX, but I'm not sure if it is the same problem and I do not have any mods.
Check here:
https://acurazine.com/forums/showthread.php?t=23667
Check here:
Just dial 1911
1 Post
Check here:
Check here:
Just dial 1911
1 Post
Originally Posted by JTso
Didn't your poly bushing come with silicone lube? It sure sounds like the D-bushing noise.
Just dial 1911
1 Post
Originally Posted by daddydliv
Bushings probably need to be lubed. I had the same exact sound that you seem to be describing. After the dealer lubed the bushings it hasn't come back.
I guess what I could do is just remove that bracket and bushing and see if I still get the squeak...I bet I wont though...
So back to my orginal question, is there any other parts of the rear suspension that might need lubing?
Professional Newbie
Did you ever figure out what that noise was? I just got a squeak last week and it wont go away, but I've had the Comptech sway since I got the car 3 years ago
Just dial 1911
1 Post
Hey Joe, what type of coilovers do you have again? When i had the Basics on my 04 the right rear top mount seem to squeak based on the temperature outside. I got some spray silcone spray and just sprayed the rubber top mount and that seem to quiet it down for about 2 weeks or so. I thinks it just the different type of material of the Tein's as compared to the Stock stuff that rubs the rubber. So spray it, or leave it i guess....
1fatcrxnem1
22
06-01-2018 01:23 AM
BoricuaTL
04-08-2016 01:08 PM
