read ECU code without special equipment
Originally Posted by blahsome
Is there a way to read the ECU code for a TSX without any special equipment? Thanks.
Back to the basics. To pull a fault code, it isn't hard, you just have to know how to use a PGM tester, know what the code really means (which involves a bit of technical knowledge when it comes to cars), and how to rectify it before you can reset the code.
I remember on my '98 accord, you could go to the data port and jumper a couple pins using a paper clip (one end went into pin hole 3 and the other when into 13 or something) and then when you turned the car on, teh check engine light flashed out the code that could then be checked in the haynes service book.
not sure if something like that would work on the tsx.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
09-15-2015 06:44 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
