Power Steering Pump and Transmission problem
Old Dec 29, 2012 | 12:40 PM
MLopez's Avatar
4th Gear
Hello, I have an Acura TSX M/T 2004 60k miles.
One of my problems is with the power steering pump when the engine is cold and I turn its makes a really bad noise, when its running and Its between 2.500 and 4.000 rev Its make an rare noise like an electric noise(Im not sure if this noise is power steering pump related) and when I do a fast U turn the power steering go off and the steering gets really hard.
I know It is a common issue but I need the be sure of what parts I need to replace.
My second Problem is with the transmission. When I let the car parked for a long time (like 6 to 10 hours) when I shift to second gear the car makes a rubbing sound. What I need to check?
PD: I live in Dominican Republic thats why my bad english and we don't have an Acura dealer here so don't tell me to go to the dealer.
I'll Really apreciate your help.
Old Dec 30, 2013 | 11:55 AM
ostow's Avatar
3rd Gear
hello to your noise power steering, put your vehicle on and look in your oil tank has power steering if there are air bulb surface. if there is air buld look at your o-ring for input or output pump this problem often and approx costs $ 5 o-ring. I had this problem when he started getting cold.
sorry for the translation I just speak French.
Old Dec 30, 2013 | 12:46 PM
TexasHonda's Avatar
To supplement previous poster, the oring is on the suction inlet fitting at the power steering pump. About 10 mins to replace.
good luck
Old Dec 31, 2013 | 02:31 AM
CJ Majesty's Avatar
Wouldnt happen to have part numbers, would you?
Old Dec 31, 2013 | 09:09 AM
TexasHonda's Avatar
See attached pic. It's part 11. Check acura parts, PS pump info.
good luck
Attached Thumbnails Power Steering Pump and Transmission problem-14sea01_e1901.png
TL-Rocket
Apr 29, 2023 02:33 AM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
asahrts
Sep 4, 2015 05:55 PM
