Power Steering Noise
Hi -
Did a search on "power steering noise" and "power steering whine" but did not get any good hits.
My '04 TSX has developed a power steering "whine" upon cold start. At times, it's quite loud, and other times it is "noticeable". About one year ago, I lost some power steering fluid due to a hose problem. Also, my car sits in the garage, hooked to a battery maintainer/charger for probably 4 - 6 months each year (I travel a lot for my job). The car was purchased new in October '03, and has 78,800+ miles.
The "whine" sounds like when you've put in a new rack, and are adding fluid (turn the rack to one end, fill, turn the rack, etc), only louder. The "whine" does occur at times on a hot start.
There are no noticeable leaks, and the fluid level is good.
I'm wondering if this could be the fluid could be contaminated, or is the pump dying? Anyone have any ideas??
Thanks!!
Thanks!!
do you mean you hear the noise when you turn the wheel? if so, and the noise is present when you turn the wheel at slow speeds, get it checked out at pflueger. mine had a "groaning" "whining" "noise" when turning and i just got a whole new power steering rack. noise is gone. if your car is under warranty, go get it checked out...
Yes, the noise is louder when turning the wheel. I'd take it to the dealer, but the car has been out of warranty for some time. My Brother-In-Law is a mechanic, and he's going to check into this for me. I hope like anything it's not the rack. That will be major $$$ since the sub-frame has to come down (just had that done to replace the clutch).
Thanks!!
Thanks!!
Nuther question - since my power steering hose broke a couple years ago, they had to drain the fluid to replace it. I'm thinking now, that the fluid is okay, despite the total mileage on the car. What do you think?
I would just replace it. They may have just fixed it and added fluid. Also look at the miles then and look at the miles now.
I agree, usually that whiny noise is the pump (which to me is actually easy to replace). Just make sure your level is correct, and turn your wheels from lock to lock to ensure your lines are bled (obviously do this while the car is running).
still plays with cars
BTW, I bought a gallon of generic Valvoline PS fluid for my other vehicles and there is a specific note to NOT use in Honda vehicles.
Yup - they used the correct Honda fluid.
for EVER more!
no. taking it in for A1 service tomorrow - 48k mi now on the 06 MT. Last time they didnt hear it, i'm hearing it more often but still only about 5 times a week and at very slow speeds.
UGH. Will let you know if techs say anything (probably not) but i'm worried as warranty is almost gone-zo.
for EVER more!
I complained about it again, and the techs didn't hear it. Neither did I. Only happens when the car has been sitting (overnight 5 hours or more). Then it happens on first 2 or 3 slow speed turns (like pulling out of driveway or parking lot) and then its fine.
Is this worth getting figured out or am i being anal retentive?
It's on the suction side of the pump, and when it shrinks (when cold) it allows the pump to suck air into the fluid. The aerated fluid causes the pump to cavitate and make noise.
Has been a good fix for V6 Accords, didn't realize TSX's were having the same problem. Thanks 240sx....
However, if non-Honda fluid causes deterioration - well that's another story.
mike from annapolis
05-07-2017 08:21 PM
