Popping/Rattling/Squeaking sunroof.
So, I recently discovered the Popping (upon tilting opening the moonroof). It was also rattling while it was in the tilt position. Upon my visit to Acura today, I had them look at the sunroof. The tech ended up lubing the sunroof with WD-40, and then some Acura white lithium grease stuff. I mean, he really lubed it up. So far, so good. It seems to stop the "popping" sound as well. I guess that popping sound is attributed to a lack of lube from the factory.
Anyway's, I just thought I'd let you guys know how it turned out at the dealership.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
^^ + 1. I've read that WD40 breaks down rubber. I'm all in favor of the lithium grease, but if I were you I'd wipe everything down and then just re-apply the lithium grease without the WD40.
303 works pretty well for a temporary fix. It will last like 2-3 weeks and then it just rubs and evaporates off. I may have to try the lithium greese, just wasn't sure if it would get all over the paint if i used that.....
Weird guys, I had the same concern about the WD-40, but there isn't much I could do about it. I did ask the tech about it because I had to go for a ride with him to make sure the rattling has stopped. I told him my concerns in regards to WD-40, and he said that it shouldn't hurt anything. He said he used a little bit of it, and it didn't do anything anyway's, so then he used some Honda/Acura lithium grease stuff. He really lubed it up, and so far it seems ok, but we'll see what happens. Why is WD-40 that bad? Even if it's just used once, it will dry up the rubber?
^^ the WD40 website says that it is safe to use on rubber but if you google "WD40 rubber" you'll see a lot of different sources say that it rots rubber. I probably wouldn't worry about a one-time application, but, I wouldn't make a habit of it.
![what](https://acurazine.com/forums/images/smilies/what.gif)
