P2184 "Engine Coolant Temperature Sensor 2 Circuit Low." HELP
I need help getting rid of a P2184, "Engine Coolant Temperature Sensor 2 Circuit Low." I picked up the sensor from Acura dealer. I replaced the sensor that's on the radiator on the driver side , I erased the light but it comes back on immediately.
can anyone please help?:help:
I changed both of these sensors and I have had no luck with getting rid of the P2184..
there must be someone who has had an issue with this code...please help:help:
takin care of Business in
Received 4,732 Likes
Hope this helps:
http://www.tsxclub.com/forums/1st-ge...-location.html
when I had that code, I replaced the sensor at the bottom of the radiator and replaced the coolant. I cleared the code and it went away and never came back.
have you checked your thermostat? I believe it plays a part in that calculation also.
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
