Noise and red dust on and near serpentine belt
I just noticed our TSX is making a fairly constant squealing noise at idle which seems to come from the area of the serpentine belt. The belt does not have cracks in it...Actually it looks to be in good shape. However, there is a redish or rust colored dust on the outside of belt as well as on other components such as the power steering pump etc. near the belt. Any ideas as to what may be going on?
I had about the same. Replaced the belt and cleaned the pullys and the noise is gone. Made sure to try and wiggle the idler pully to make sure it wasnt wobblin and squekin while the belt was off as well or it needs replaced too.
I'd bet money that the red "dust" is remnants of dried water that has been exposed to something that's rusty, then thrown around by the belt. I wonder where the water is coming from....
If you temporarily release serpentine belt and spin tensioner idler by hand, you should be able to detect any bearing looseness from rattling/vibration noise. A good bearing will spin silently.
good luck
good luck
winkyyy
09-11-2015 04:40 PM
Phambam12
09-05-2015 04:10 PM
