Need Help!! 04 Acura TSX won’t idle
Car overheated over a year ago and set until recently. The car will crank over but will not idle or go over 2000 rpms. I pulled the plugs out and they were toasted so I put new iridium ones in as well as coil packs. I checked the fuel pressure and it was around 55. I took off the throttle body and cleaned it. (Didn’t seem too dirty) I also took the iac off and sprayed it with the electronic cleaner. (Didn’t seem dirty at all) I ran the codes and it’s still showing all the misfires and a random misfire. It did read a code for the map and cps sensor so I’ve changed those as well. Still cannot get to idle. Something to note is that when I make it run for a bit and it gets warm you can hear bubbling in the radiator. Any help would be appreciated. I have just rented a compression tester to try next.
Received 6,860 Likes
Hey Dylan, welcome to the forum but I've moved your post to a place where it will get much more attention. Good luck!
tastytreats
2G TSX Problems & Fixes
03-23-2012 08:55 PM
