My gas mileage suffers after 50k!
I've never complained about gas mileage on my tsx. I have gone over 500 miles numerous times before and mpg always stayed above 30mpg as I drive 90% freeway. But, after 50k, my gas mileage is going down day by day. I average about 24-26mpg and my driving habbit hasn't changed, nor my daily route. I don't carry extra weight or anything. Anyone else having same problem? I hope it's the weather that's causing it but my car has given me constant 30mpg past two years.
Sigh, I wish there's no more problems ahead
Usual checks under such situations:
1. Is the tire pressure correct?
2. Any recent change in driving style?
3. Engine Air Filter been replaced?
4. A bit early, but check the spark plugs. If necessary, drop it four new NGK Iridiums for about $40.
5. Any Check Engine Light?
Originally Posted by dwest1023
Are you using gas with ethanol? That stuff burns like water. Try a tank of Chevron or BP and see what you get.
My 04 TSX has 53,000 miles on it, and I have gotten up to 32 miles per gallon on the highway.
Make a hole, coming thru!
Originally Posted by n3ok318
I've never complained about gas mileage on my tsx. ...
- Has all scheduled maintenance been done?
- Have you changed gas brand?
- Do you run the a/c more? Or ... have you had the cabin air filter changed in the last year (a clogged filter makes the HVAC work harder, I'm told)?
- Are you running on OLD tires, aside from checking the cold air inflation?
- Have the tires been rotated and balanced recently (within last 6000 miles)?
Originally Posted by xrarey
All oil companies sell gas with 10 percent ethanol (including Chevron and BP)....
Not in my area. It is suppose to be posted on the pumps if it has ethanol in it. In my area Texaco, BP and chevron do not use it.
Well, then I should say that all I have ever been able to use is 10 percent ethanol, and I get 32 mpg on the highway (53,000 miles).
Hmm.. all maintenance has been done and I use Shell 91 Octane only and I've been using it since I bought the car. Believe it or not, my gas mileage does not change much even if I have full AC on all the time (maybe 1mpg at most) and I changed AC filter around 50k.
Along with the filter, I changed all my tires. And yes, I changed them at 50k. They're Yokohama so they aren't stock. I think it's the tires causing the drop on gas mileage. Argg.. They perform so much better than stock. But I guess in exchange, it gives bad mileage.
Bingo. Different tires can effect MPG, I'm told. If you get better performance than Michelins or Nexens, then the trade-off is probably worth it. Particularly if you experience less tire-road noise. I hear that complaint regularly.
How was your cabin air filter? I'm thinking of starting a thread of "worst HVAC filter" photos. Some wait the whole 30,000 to change, and I can only imagine the filth that's in there.
Well, I changed mine at 50k for the first time and it was very clean.
I heard horror stories about them being extremely dirty, but mine was so clean that I could've use them again after shaking the dust out couple times.
But I used new one since there might be hidden micro dusts
if you want to get better MPG, run some seafoam through the car. in any gas car, there will be some buildup of carbon and gunk in the motor, seafoam helps get rid of it and works well.
I think its the tires. I changed mine at 48k and that's when my mileage changed. I thought it was because I was driving faster with my new setup. I went from a consistent 26+ on my drives to a 22-23.
Well, I changed mine at 50k for the first time and it was very clean. ... I heard horror stories about them being extremely dirty, but mine was so clean that I could've use them again after shaking the dust out couple times.
*Can't say which one, can't read the online manuals from Linux at work. Guessing ... 20K and 40K?
Hm, maybe mine's different from all others?
My friend changed it along with me (he civic with 30k miles) and it was filled with small yellow dusts. But mine on the other hand was so clean, just some pieces of scattered leaves.
And NO, Acura wouldn't have changed them for free because I paid $35 for oil change and nothing more all the time.
Who said anything about free? ("Free" and "dealer" are rarely used together in a sentence.) Some of the periodic maintenance visits have a whole slew of items. Are you telling us that over the 50,000 mile lifetime of your car, you've only changed the oil? Did you buy this car new?
What I'm driving at is that there is another reason why your last cabin filter was "so clean that I could've use them again" than it just wasn't getting dirty. Could be your environment, could be the result of a prior servicing, or ... I dunno, maybe you guys hve little Cabin Air Filter Fairies up there who change filters during the nighttime. Boy I wish some of those CAFFs would migrate south....
Rep'n Taxbrain.com
Originally Posted by PACman
O2 sensor could be going, but a CEL should show up if it does.
