LED Blinkers
9th Gear
LED Blinkers
I did a search on this and came up with nothing relevant. So I wanted to run it by you guys to see if anyone knows of the fix for the LED Bulbs in the blinker housing blinking fast like a bulb is out? I know it has to be a Ohm problem or the relay. Anyone know of the best way to approach this? Any help or products is much appreciated!!
3 ohms if you're doing 4 blinkers(2 front, 2 back), and 6ohms if you're just doing 2. And you just need two resistors in both cases because they run in series, so the current is the same.
9th Gear
Thanks for that info! That helps me out a ton. I really appreciate it. Thats why I love Acurazine!
that's weird. I had some LED "bulbs" lying around and decided to try them out in my '06 tsx. They worked fine, perhaps there is already a resistor in line because of the LED blinkers on the mirrors?
Eggs999bacon
09-24-2015 10:08 AM
