ingall front camber kit making bagging noise
Ok need some help guys I installed my ingalls front camber kit today and after I go for a ride when I hit a pot hole. I hear the top nut That mounts on top of the Control arm banging on the chassis for some reason i has to be that.. and I only hear it from the driver side .. How can I fix this problem ??,
Go check the underside of the shock tower for a dent. If you see one, then the camber kit top mounting nut is hitting it. If you are lowered using full length shocks (such as stock) with springs, then the upper control arm will go up higher and makes the problem worse due to decreased in clearance.
ok im gone do that when i get out of work i got koni yellow shocks
Let me help you!
The only people who get front camber kits are people who track/auto-cross and want to purposely change the camber of the front wheels.
The rear suspension, since it is designed differently than the front suspension, will need a camber kit if you go too low. The rear wheels will get more negative camber the lower you go; the front wheels will barely get any negative camber even if you slam it.
With the way that the TSX is designed, you don't need a front camber kit. Thus, your statement is invalid.
I'm not going Autocrossing I'm going to limerock in spring. So. The camber ain't for looks and my car was slammed witch I didn't do on purpose . but I rised it bak up and inch. Tomorrow I'm getting my alighment so I'll be set . Thanks for the info do
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
