Hub centric ring fitment. HELP!
i'm running my enkei evo 5's with a center bore of 72.6 without a hubcentric ring, and the stock bore is 64.1. do i need a ring???? i haven't noticed anything different and i really don't know what to look for, like vibrations or shaking etc. any info would be greatly appreciated.
i guess i noticed a little bit, what size hub centric rings would i need? and is it okay to drive around without the rings for awhile? i just drove back up to college about 300 miles.
Some wheels are desinged in a way, when u use appropriate lugs nuts, it will help center the wheel. U should be able to tell wether there is a vibration or not from the new tires at high speed. I use to drive a civic with after market wheels and no hubcentric rings for years and the only problem i had was vibration. Make sure when u drive long trips, the lugs are tighted, or inspect them before taking the trip. by the way, i beleive u can ge those rings at ebay.
Got mine for my ROTAs from this seller.
Fit like a charm and no rust or anything.
http://cgi.ebay.com/ebaymotors/HUB-C...spagenameZWDVW
