HID beams converge
HID beams converge
I had my headlights replaced under warranty due to condensation back in December. The new headlights have more pronounced step (I noticed it after looking at the photos by San-AnT) pattern and they converge (it's more noticeable due to the pronounced step pattern). Is this normal? It has been bothering me since I had them replaced. Anyway I can fix this myself and make the beams more parallel to each other?
Originally Posted by GIBSON6594
That's just the aiming that the dealer did when they replaced the lights. No biggie. If you really want to... you can just readjust the lights to different heights.
I read on the hidplanet.com forums that after '04 they changed the actual projector used and the lense design that ended up altering the beam pattern + cutoff and making it less desirable compared to the original design. I have no valid info to back that up other than several HID comparison tests and the guys over there that are OBSESSED with HID/Xenon lighting. "OBSESSED" being an understatement......
Originally Posted by Agent11br
I read on the hidplanet.com forums that after '04 they changed the actual projector used and the lense design that ended up altering the beam pattern + cutoff and making it less desirable compared to the original design. I have no valid info to back that up other than several HID comparison tests and the guys over there that are OBSESSED with HID/Xenon lighting. "OBSESSED" being an understatement...... ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
