Help! Dealer recommended new transmission drain 4,000 miles after previous one?
HELP. In Sept 2011, I got a transmission drain and fill at the dealer for $120. In February, 4,000 miles later, I got a coupon for an oil change & went back to the dealer. The service guy told me the transmission needed a drain and fill. I said - you did that in Sept. He said the previous one hadn't been noted in the computer and it was a mistake. 6,000 miles later, I got another oil change coupon at the dealer and the service guy tells me again, I should have a drain and fill as the transmission fluid is dirty. How can this be? It's only 10,000 miles after the previous one? Should I be suspicious or get the transmission fluid changed again?
I mean when I had a manual transmission car, I generally changed the transmission oil in the vehicle once every 3-4 oil changes. With automatic, I do it once every 4-5 oil changes or I try to get it done once every year or two. I'd be kind of suspicious though. Seems like they're just tryina get ur money.
Adina (10-15-2012)
If fluid is dirty (did you look?), then they likely never changed it previously. Fluid <5K miles should look very clean.
I suspect AT service is pushed hard a dealerships, because they mark up bigtime and share w/ the mechanic who recommends. That's why I diy.
good luck
good luck
good luck
good luck
Every 30,000 miles sounds very reasonable. Thanks to everyone's responses, I think either they never did it the first time or are trying to get extra money. Will check to see whether the fluid is dirty myself on a regular basis. Meantime, I found a mechanic who services a lot of Acuras and who will do a drain and fill for a lot less $$$ than the dealer. Will also check after any service to make sure the fluid looks clean.
When you change your transmission fluid only half of it actually gets changed. THe rest is still in your transmission. So after a couple of thousand of miles of driving the dirty fluid mixes in with the new fluids. So generally it takes a couple of transmission fluid changes and couple of thousand of miles intervals to get all the dirty transmission fluid out.
Do not get a transmission fluid flush. Follow the transmission fluid change as described above. Honda does not recommend transmission fluid flush as manfacturing shavings and such can get stuck in the transmission internal parts and damage your transmission.
Adina (10-17-2012)
in the 24th and a half...
The independent is a good idea, espcially if he come recommended by others. Keep a close eye on him at first, and then you can relax a bit as he proves he's in it to help you.
Best advise I can give with an independent shop is to take all your business with that car there...then they know they'll keep getting business and have an incentive to do it right and treat you well.
Adina (10-17-2012)
Perhaps that's why, the fluid is dirty again. Still seems a very short time to get dirty enough for another drain and fill. Being a newbie Acura owner, I was/am totally unsure whether they did it the first time. Appreciate the warning about the flush. The dealer first wanted to sell me a complete flush instead of the drain and fill.
Yes, this sounds correct.
You want an independent who has the right equipment to work on your car. That means a HDS computer and the shop manuals. Ask them to verify they have this available. Also ask if they charge by book time or actual time.
Thanks! After everyone's responses, I called the service guy at the dealership and he said he would talk to the manager. He called back and told me in the drain and fill, they only exchange 4 of 6.9 quarts. He said that's why the Owner's Manual says you should have a complete flush and during a complete flush, they drain and fill three times. He said that's the only correct way to change transmission fluid...I will go to the independent and ask whether they have the HDS computer and shop manuals as you suggest and get another drain and fill, not a complete flush, despite the dealer's recommendation. Appreciate your insight.
I would look at your owner's manual. Or a service manual relating to your vehicle. A flush may do damage to your transmission.
Its a gamble, paying 100 bucks only 3-4 times every few thousand miles to change your transmission fluid or few thousands to replace your transmission.
As mentioned previously the metal shavings getting stuck in your internal components during a flush from when your transmission was originally manfactured is a risk. That is why the drain bolt for your transmission has a magnetic inner tip to catch as much metal shavings at it can, but it does not catch them all. And a flush does force fluid through your transmission and the debris have a greater chance of damaging your transmission. Decide for yourself.
The "drain and refill" only replaces 3 quarts of ATF each time, not 4, so your transmission fluid is bound to look dirty only after a few thousand miles when only about 40% of the fluid in the transmission is replaced.
The ATF Capacity is 6.9 quarts (7 quarts).
The proper way to change the transmission fluid is the "drain and refill" three times. If you do this at the dealership, it's bound to cost way more then $120. The ATF cost $8-$10 a quart depending on where you shop.
Your other option is to find a independent repair shop and give them 7 quarts of Honda(Acura) Automatic Transmission fluid and have them fill it in there Transmission Fluid Exchange machine. My local Jiffy Lube has a newer transmission fluid exchange machine that lightly sucks out the old fluid (Doesn't push or puncture anything like seals). Sucked out ~ 7 quarts and replaced with 7 quarts. I do this one every 60k miles.
TerpNation (10-31-2012)
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
