headlight fogging up
its not because of a defect in the headlite its cuz i replaced my ballast with TL ballast and it doesnt fit propering through the wire hole so cold air is leaking into the headlite and mix with the warm temperature of the headlite causing it to fog up. So I will have to modify the hole to make it bigger for the ballast to fit through. My question is how can i get rid of the condensation thats alread behind the lens. Can i use a blow dryer through the bulb holes some how?
my original headlight broke and water got in and blew the ballast, so i had to get new housing and ballast and found a good deal on the TL ballast and stupid seller said TL ballast would fit fine on the tsx housing. so yeah problems problems...thanks for the reply! any more suggestions?
You can simply take a hair dryer or heat gun and apply heat from the outside (front of lens) without taking anything apart. It will take a few minutes for the lens to warm-up, then everything will clear up quite quickly. However, you still need to find a way to prevent it from happening again, like seal up any gaps.
